407 headlight bulb help please!!!
slaidlaw81
Unread post by slaidlaw81 »
Hello all,
What bulb is needed, where can i get one and is it easy to do?
thanks for any help
Toby_HDi
x 3
Unread post by Toby_HDi »
Any motor factors will stock bulbs. Halfords do them though can be quite expensive. The only exception would be if you have HIDs, in which case your best bet is to search the net for some good quality bulbs. They fairly simple to do, though if its anything like the 406 expect to lose half your knuckles and to make a blood sacrifice to the gods of Peugeot headlamps!
Depending which bulb has gone will determine what bulb you need, I'm assuming its a front one...
Halogen Dipped Beam - H1
HID (Xenon) Dipped Beam - D2S
Main Beam - H7
Fog Light - H11
Main beam is on the inside and Dipped is on the outside of then lamp units.
Toby
Previous:
2004 Peugeot 407 HDi 138 SE Luxury Pack
2001 S2 Xantia HDi 110 SX
2001 Peugeot 406 V6 Coupé
1998 S2 Xantia Activa
2000 S2 Xantia HDi 110 SX
1999 Peugeot 406 2.0 16v Estate
slaidlaw81
got it done, i was being a biff! it was the H1 bulbs, had to go to halfrauds but the fancy bright lights were buy 1 get 1 free!
