406 2.1 oil leak
studsmassive
406 2.1 oil leak
Unread post by studsmassive »
hi guys the engine has a oil leak at back of engine from up top any help please
also the aux belt seems to floppy fully adjusted
thanks darren
peugeot 406 2.1 diesel
x 1240
Unread post by Peter.N. »
Most likely candidate is the rocker cover gasket.
I suspect you need a new belt
studsmassive
hi thanks for reply i hope its just the gasket and nothing more
also i have changed the belt its a 6 pk 1940 ive took it back and got a 6pk 1930 from a bmw its 10mm shorter hope this works
poddack
Unread post by poddack »
I would check the belt tensioner and idler too
