Cheap code reader for a 2002 diesel?
Nick69
Unread post by Nick69 »
Thinking about getting a cheap code reader for our cars, '02 c5 2.0hdi and '04 renault laguna 1.9dci.
Is there such a thing that is cheap as chips? I see the Elm327 ect on ebay but says 2004 diesels onwards?
Main reason is the C5 has a beep on start up but thought it would be a good idea to have one.
Anyone?
Nick
x 1923
Unread post by Paul-R »
Diesel cars did not have to be OBD II compatible until post 2003 so a generic reader won't won't work on the Citroen. It should work on the Renault however.
In order to read the C5 you will need a Lexia reader or the use of a high-end multi-vehicle reader (Snap-On, Sun, etc). A Lexia would be better as it can investigate deeper than any non-specialised reader can. It isn't, however, all that easy to interpret what it says sometimes!
Nick69
Paul-R wrote: It isn't, however, all that easy to interpret what it says sometimes!
Or cheap, I will have a looksy and see what comes up.
Thankyou :D
x 1923
Depends what you mean by cheap, I suppose.
Lexia hardware and software (Chinese clones) are available for about £300 from Ebay I believe. Providing you have your own laptop (Win 2000/XP and (I think) Vista) this a lot cheaper than the thousands that Snap-On would want for a reader.
