Xantia Hdi 1999 total lighting failure
nobbi1977
Unread post by nobbi1977 »
I have just been given a Xantia HDI 90 1999 with 96k on the clock by my Dad who owned it from 6 months old.
I was driving along at 7 in the morning and when I went to dipped the lights everything disappeared.
The indicators and brake lights work but nothing else.
I have stripped and inspected all the electrics I can get to and can’t find a fault. The plugs all test as 12v or ground so I suspect the switch is U/S.
Is this a common problem with S2 Xantias? I don’t want to spend £40 on a switch to find that is not the problem.
Are there any tame dealers / breakers on here that can do a better deal than Ebay?
nobbi1977
Ordered a switch
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 0468042594
Hope it solves the problem
andmcit
x 30
Unread post by andmcit »
It certainly points to the switch so your diagnosis sounds right.
Just one thing to watch with the replacement switch is it's compatibility with
your car as there have been various permutations most significantly with the
estate models with the rear wiper being controlled differently to the saloon.
If the image on the auction matches you could very well be fine though.
Andrew
nobbi1977
I have matched the part number from the switch here
http://www.autocarspare.com/catalog/col ... 25375.html
so I hope it is correct. Looks the same with the horn on the wheel not the stalk
nobbi1977
Switch was not the problem
I got an autoelectrician in the end. He bypassed a bit of faulty loom and its all good again.
Just need to finish sorting thr brakes now
Xantia HDI 90 1999 (Free, Thanks Dad)
Renault Grand Scenic 1.9 DCI
Renault 5 Campus (Free,Took it to the scrap yard)
Peugeot 405 SRI (I loved that car!!)
Peugeot 405 1.6 (The boat)
Peugeot 309 (My first frenchy)
