307 - Water in footwell
sooty
Unread post by sooty »
From the last few days of continous rain.
The L/H front footwell has a pool of water under the Rubber mat.
Its not coolant water as the header tank is still at the same level as always.
As far as I can see, the left hand heater vent under the windscreen is not blocked with debris looking through the mesh. Looking at the R/H side the drains down side of inner wing and L/H drains but behind battery ? oe could it the door seal.
The car mostly parks facing down hill if this is any help
Any clues ???
Ex 307 2.0Hdi 90 bhp 2003
Ex Grand C4 Picasso VTR+ 2008
Ex Vauxhall Insignia SRI 2.0 CDTi 2010
C4 Picasso 1.6 HDi VTR+ 2014
boeingmech
Unread post by boeingmech »
if it has a sunroof check the drains by inserting a thin rod/wire, i used a bike gear cable down the drain from the top corners of the sunroof
sooty
thanks,
but no sun roof fitted
boeingmech
can you get someone to sray a hose on it whilst you sit isde to look for leaks? how about the aerial is it on the roof? could be door liners has it got a pollen filter? if so has it been fitted properly?
