BX Starting Problem
Boothers
BX Starting Problem
Unread post by Boothers »
The Orange glow plug light is not coming on the dash, and when turning the engine over it takes about 10-15 seconds before it starts. Is this just a glow plug problem or something more serious?
Jason
BX19DTR & 17TGD
tomsheppard
Unread post by tomsheppard »
No, I suggest that the relay is not operating. A test lamp from a glow plug terminal to earth should tell you if this is so. Check the supply to the relay before discarding it!
ghostrider
Unread post by ghostrider »
Yeah also check the Earth side of the relay which I am fairly sure is connected to the earth bolt on the inner wing just behind the battery
Pete
________
HONDA GB500 SPECIFICATIONS
