01 Megane Coupe Brakes
Martyn718
Unread post by Martyn718 »
Evening all, Not posted in a while, but have a quick question if anyone can answer it.
I am running a 1.4 16V Megane Coupe (01) which has drum brakes on the rear, what I would like to know is, is it possible to convert it to discs? If so what would need doing to complete it? And may I need to use bigger discs at the front?
Thanks in advance for any help or advise.
Martyn
evilally
x 3
Unread post by evilally »
I would imagine you'd need to swap the axle from a megane that does have discs. Do note, that discs at the rear will not make you stop any faster!
'97 406 1.9TD, 314k.
