please help !!!!!!!!!!!!!!!!! after a successful cam-belt and water pump change the car ran beautifully did 20 miles or so then stood 4 a week, started first time and ticked over great, wot happened next was that the engine ran erratically and stalled, we noticed that the bottom pulley on the crankshaft had become loose and sent metal fillings everywhere.
we were advised to replace the pulley, magnetic ring and sensor after cleaning it had failed to make any difference to it starting.
these new parts have not solved the problem.
PLEASE IF ANY1 CAN HHHEEELLLPPP.........................
2ltr hdi c5 05 plate help will not start
- x 1496
First check has got to the cam timing - possibly disrupted by frgaments from the pulley. If that checks out OK, then could be low P pump in the tank - try giving it a whacking underneath whilst cranking it. After that you will need to get it on a diag machine to see what's going on.
Bad luck....
Bad luck....
citroenxm
- Fallen Hero
- x 70
trinity060
citroenxm
- Fallen Hero
- x 70
Ahh the cheaper of the failiures... These pumps arent that badly priced now on the Bay...
Nice easy ish job to do, infact, probably the easyest of the failiure items to go...
Paul
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
trinity060
god damn it
ok well pump saurced and fitted we now have fuel but all we get when we try to start it is a couple of lumpy revoloutions cough slutter cut out, can the ecu be reset? is there a man with lexia around the b'ham area? can u even do lexia with the car not running? realy not happy now if any1 out there can help my mobile is 07860865769
MARK
87 bx 1.9d
89 405 1.9d1
94 xantia 1.9td vsx
96 xantia 1.9td sx 275000m
96 berlingo van 250000m
98 xantia 2.0hdi excl 110 350000m
87 bx 1.9d
89 405 1.9d1
94 xantia 1.9td vsx
