C8 OFFSIDE SIDELIGHT
alden
AM I RIGHT I THINKING THAT I NEED TO TAKE OFF THE WHOLE UNIT TO ACCESS THE BULB AND IF SO HOW AS I CAN ONLY FIND TWO BOLTS (ONE AT TOP AND ONE AT SIDE NR TO BONNET CATCH
BX 19 TRS
C5 SX EST 2.2
C8 2.0 SX
C5 SX EST 2.2
C8 2.0 SX
quintet
- x 44
Chances are is that the lower bolt is hidden out of sight by the bumper which would need removing in order to gain access to it, not clever! but i don't ever recall seeing anyone having to remove the bumper to change a bulb (not even on c5's which are awkward), generally a bit of cursing is involved but I'm pretty sure they're accessible with out removing the headlight (a small mirror & a torch will help see into the back of the headlight unit).
Unfortunatly the c8 is one of those cars i always found to be a pain to work on, even filling the engine oil up is a pain!
Music keeps me going.
- x 1055
OT a bit but my top tip for filling the oil on a C8 is to undo the little 8mm bolt on the remote filler neck & squeeze the hose clip thing off & just push a small funnel into the rubber pipe, makes it a whole lot easier, its much quicker & saves clearing up all the spilled oil that has gurgled back & spilled all down the engine.quintet wrote:Unfortunatly the c8 is one of those cars i always found to be a pain to work on, even filling the engine oil up is a pain!
I would agree, you dont need to remove the headlamp to replace any of the bulbs in the headlamp assembly on a C8.
swervo
Re: C8 OFFSIDE SIDELIGHT
Does anyone have any tips on this please?
I can find the back of the light but there aren't any wires or any obvious way of releasing the bulb.
The rear of the light feels like a small rectangular box which is part of the unit.
Any advice warmly received. Thanks.
Citroen C8 2.0SX Hdi auto
Previously (ZX 1.9D estate auto, BX, and a GS)
alden
spring clip holding in the housing, release this and bulb is loose to slide out.
BX 19 TRS
C5 SX EST 2.2
C8 2.0 SX
C5 SX EST 2.2
C8 2.0 SX
