406 timing belt
studsmassive
406 timing belt
Unread post by studsmassive »
hi there people i am doing the timing belt on my 406 2.1 td could anyone tell me what a good price is for a kit as i want to do it as cheap as poss thanks
darren
peugeot 406 2.1 diesel
x 1240
Unread post by Peter.N. »
The idler and tensioner on these engines are usually very reliable, I have never changed one yet in 14 years of 2.1 XM ownership, it is suggested that you change the water pump at the same time as its driven by the cam belt, but again I have only ever had one water pump fail, and that was just after I changed the belt :x . So, if you really need to save money check the idler and tensioner by feel and sound and make sure there is no sign of water leaking from the pump - then it will just cost you the price of the belt.
Citroenmad
x 110
Unread post by Citroenmad »
Id always say change the water pump with the cambelt, as they have a habit of failing after you have changed the belt. Plus most old water pumps show signs of leaks.
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
Oldpug
x 94
Unread post by Oldpug »
Doing a cambelt change as cheep as possible defeats the object.Use an OE kit £60-£75 and pay very close attention to the water pump and the auxiliary belt and its tensioners.
x 8444
Oldpug wrote:Doing a cambelt change as cheep as possible defeats the object.Use an OE kit £60-£75 and pay very close attention to the water pump and the auxiliary belt and its tensioners.
Agreed. Waterpumps always fail just after a timing belt change if you don't replace it.
The cambelt tensioner though, I'm with Peter here. It's sturdy and if it spins silently and is free of any play it'll do one more time no worries.
Do though, as OldPug says, pay very close attention to the auxillary belt tensioner. they fail regularly and I'd be tempted to replace it as a matter of course.
studsmassive
thanks for advice i ordered a cambelt kit and aux belt i will risk the water pump as no signs of leaking
darren
panason1c
Unread post by panason1c »
Just bear in mind that the water pump will need to last for about another 60k miles before the next timing belt change........... i renewed my water pump when i fitted my new timing belt kit just for piece of mind.
studsmassive
well i have changed the water pump aswell im glad i did like always its a peice of mind it is all working as it should im so happy
panason1c
studsmassive wrote:well i have changed the water pump aswell im glad i did like always its a peice of mind it is all working as it should im so happy
Glad its sorted.......... :wink:
