Berlingo van rear light
danielhawkes
Unread post by danielhawkes »
Anyone know where the door switch is for the rear light in a 2000 berlingo (Partner) van ???
x 1240
Unread post by Peter.N. »
If you can't find one it could be a tilt switch inside the door.
danielhawkes
can find a pin switch.
poking all the catches seams to do nothing.
no wires running to the door that opens first (wires run into the 2nd door - might just be for number plate lights tho).
spider
x 77
Unread post by spider »
I seem to think its in the actual catch for these (I could be wrong, it has been about five years since I last worked on one) :)
206 doors are the same too, there's no 'pin switch' its done with the latch itself.
If your van has the single rear hatch it might have a mercury tilt switch but as yours has the double door I'm sure its the latch that's the switch on the later models.
Andy.
danielhawkes
ok kewl, i will take a look at the weekend
