HDi EGR Valve or Turbo
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
Hi All..
Subject: HDi 110bhp, Xantia
Ive got a Xantia 110bhp HDi here, I have found that if I undo the EGR valve the engine will run etc.. however, ifI tighten it up the engine wont run, and starts and stalls immidieatly..
I bought the car with a suspect turbo problem, so my Q is, is this an EGR problem, or is there a Turbo blockage causing the gasses to go in the direction of the EGR?
Paul
A very sad...
1994 XM 2.1 d auto
x 8423
Paul, if the engine only runs with the EGR valve loose then this suggests a big blockage, the engine is breathing via the loose valve. If under these conditions the EGR valve is acting as an air inlet then the is a blockage 'twixt the air filter and the inlet manifold.
If there are exhaust gases coming out of the valve then the exhaust is blocked, maybe at the cat. It's not unknown for a cat to collapse totally and block itself up. Don't be too quick to condemn the turbo. It could be something as simple as a collapsed hose between the turbo and intercooler.
Brigsygtt
Unread post by Brigsygtt »
Im with Jim on this one, ive absolutely destroyed turbo's in the past and the engine will still run fine albeit slowly & smokey.
Drop the exhaust off and run it, if the turbo's goosed oil might have blocked the cat.
97 Xantia 1.9 td lx with a/c (Daily, 172K, FOR SALE)
98 Xantia Hdi Lx with a/c (105k)
97 Renault Extra (c1j turbo 230+hp, 12.88@106)
91 Renault 5 Gt turbo (68k minter)
citroenxm
Fallen Hero
x 70
Ah, good point, I didn't get as far as dropping the exhaust off, I dropped it off the head with manifold firstly, then found it ran, so bolted the manifold and turbo back up, and it stopped, so I undid the EGR and it ran again....
Ill try the exhaust next, Its NOT a intercooler pipe they are all in good shape.
Paul
A very sad...
1994 XM 2.1 d auto
