HEATER RESISTOR
karlgixer
HEATER RESISTOR
Unread post by karlgixer »
hello
can some one tell me if the 2ltr HDI 2002 picasso exclusive fitted with climat control has a HEATER RESISTOR fitted ind where it is located on a right hand drive car?
thanks
karl.
karlgixer
the problem i have with my 2 ltr hdi picasso exclusive is the heater blower has stopped working
it did the same about 2 years ago and i had the relay mod done on the ignition by citroen dealer and all was well but it has stopped again
cheers
karl
Clogzz
x 40
Unread post by Clogzz »
Welcome to blower problems Karl ! :twisted:
Air conditioned cars don’t have resistors.
The 2002 Picasso should have a lot in common with the Xsara and Xantia, so would first need checking the blower plug under the dash above the passenger’s floor.
The plug is in the habit of going intermittent from the high blower current.
If it looks normal and tight with no blackening, we’ll have to look upstream at the relay, the fuse and the ignition switch.
karlgixer
Clogzz wrote:Welcome to blower problems Karl ! :twisted:
right
i wiggled the wires and the blower started working
is there anything i can do to stop them coming lose again?
cheers clogzz
Clogzz
x 40
You can tighten the connectors in the plug with a small screwdriver through the openings.
There’s also the rough way of tightening them with long-nosed pliers from the outside of the plug.
If the thick red or thick black wire connectors are discoloured or blackened from heat, that’s where the intermittency is.
I doubt that the stealer did the relay mod two years ago.
Permanent relay circuits were wired in at the factory from 1998 and improvised relay mods dangled in for over a year before that.
karlgixer
Clogzz wrote: I doubt that the stealer did the relay mod two years ago.
just checked and dealer did the relay mod 26 months ago
its all working now cheers
