Xantia's extra glow plugs
jonnydrumm1967
Unread post by jonnydrumm1967 »
Apologies if this has been covered before,for i'm sure it has..
My Xantia SX Hdi has 4 glow plugs in a plastic housing that's in the heater hose at the bulkhead.Just noticed them today :oops: What is their function?
Thanks.
2000 XANTIA HDi 110 SX Est
1992 205 GTI TD
1996 DISCOVERY TDI
2001 XANTIA HDi LX
1991 205 D Turbo
imperial21
Unread post by imperial21 »
It warms the coolant on the supply side of the heater matrix, to give you heat in the car faster, helps for clearing the windscreen etc as the HDI engine does nt warm as quick as the petrols. (so i have been told ! )
1999 Xantia exclusive 110BHP !! Now RIP !!
2002 C5 estate 110 hdi, Happily sold on !!!
jonnydrumm1967
Thanks for the quick reply!
I'm pretty sure they don't work then,will have to pull them out and test.
Cheers.
1992 205 GTI TD
1996 DISCOVERY TDI
2001 XANTIA HDi LX
1991 205 D Turbo
x 1471
Unread post by xantia_v6 »
How well do these things work (when they are working)?
What are they controlled by?
What would be the logistics of fitting them to a petrol Xantia?
DickieG
Monaco's youngest playboy
x 33
Unread post by DickieG »
Their purpose is as Imperial states to heat the water entering the heater matrix, they are controlled by the engine ECU via two green relays located either side of the pink headlamp washer relay within the fuse/relay box behind the battery.
The unit comes into operation a couple of minutes after starting the engine and remains on until the coolant temperature reaches about 80°c.
Removing the unit is a complete pain in the you know what as it is secured by two totally inaccessible Torx screws to a metal bracket held onto the bulkhead by two 13mm headed bolts which are located under about six metal hydraulic pipe's.
How do I know all this? Well the unit on my HDi is leaking in the joint between the two halves of assembly so I've managed to remove one from a HDi in a breakers yard which was a right old palaver.
You could potentially fit one to a petrol car but I'd wonder why you'd want to, apart from the additional wiring and water pipe adaptations you'll also need to upgrade the alternator to the 120 amp one fitted to HDi's fitted with this unit.
Having now owned a later HDi Exclusive with the Eberspacher diesel burning heater and now one with the glowplug heater, comparing their heating performance, the glowplug one gets going quicker but once underway (it takes the best part of 5 minutes) the Eberspacher one produces more heat to get the engine temperature up to operating temperature, ultimately swings and roundabouts.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
spider
x 77
Unread post by spider »
There would be little point fitting to a petrol engined car apart from extreme (really extreme!) cold climates. :)
As has been said its to provide some warmth as the HDi does not warm up very quickly in cold conditions.
Andy.
Xsarahdi
Unread post by Xsarahdi »
Would a Xsara HDi 110 have these? :?:
2005 C3 1.6 HDi 110 VTR
2003 Xsara 2.0 HDi 110 SX
1999 306 1.9 TD Meridian
1996 ZX 1.9 D Elation
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
Likely, as the HDi is soooo slow at warming up...
Look at the heater hoses, at the back of the engine bay! You wont miss it if its fitted!
Paul
A very sad...
1994 XM 2.1 d auto
