Xantia steel wheel and tyre sizes?
ashy90
Can anybody tell me what size the steel wheels are that are fitted to the Xanta? Also what tyre size is standard? Cheers.
VertVega
- x 13
Toby_HDi
- x 3
Both my previous HDi and my current Activa have worn 205/60/15
The HDi had steel wheels and the Activa has alloys
EDITED: to correct rim size
Toby
Previous:
2004 Peugeot 407 HDi 138 SE Luxury Pack
2001 S2 Xantia HDi 110 SX
2001 Peugeot 406 V6 Coupé
1998 S2 Xantia Activa
2000 S2 Xantia HDi 110 SX
1999 Peugeot 406 2.0 16v Estate
Previous:
andmcit
- x 30
Toby, I'm certain 16"s aren't a standard fit!
Coincidence with your HDi's - what rim design did they come with then?
The largest OEM wheels are 15".
The base saloon models had 14" then standard 15" on the VSX and Activa
and estate models. Sure, 15" probably got rolled out and updated on later
saloon models over time but steels will always be 14" or 15" as standard
and fitted as the spare.
Tyres are standard spec at 185 65 14 / 205 60 15 with varied varieties of
section to profile permutation.
I've got the set of owner handbooks here so will run through the sizes shown
asap...
asap...
Toby_HDi
- x 3
You are of course right Andrew
My apologies. I must have got confused as my Coupé runs on 16s
I shall edit my original post!
Toby
Previous:
Previous:
DickieG
- Monaco's youngest playboy
- x 33
andmcit
- x 30
Maybe re-reading the question I didnt fully answer it properly,
hopefully this should help with alternative fitments:
Make : Citroen
Model : Xantia
Year : 93 to 99
PCD : 4x108
Offset : 15 to 20
Bore : 65.1
Fixings : M12x1.25
There are plenty of good wheel comparison sites and ones to dial in different
fitment tyres: when I'm at my machine I'll post a few links; the downside of
a smartphone...
Andrew
Make : Citroen
Model : Xantia
Year : 93 to 99
PCD : 4x108
Offset : 15 to 20
Bore : 65.1
Fixings : M12x1.25
a smartphone...
Andrew
