C5.HDI. VTR 56 PLATE AUTO 70K
tramnut
Rear estate tailgate glass not opening. Citroen dealer says 'Requires mod to tailgate gless wiring' £140 any information would be helpfull thank you all and a happy new year too.
- x 5662
It does require a mod to the wiring but not £140 worth.
It is possible to do it yourself in about twenty minutes. You need a bit of fairly fine sheathed wire, some black tape and a soldering iron.
I was too lazy for that and had an auto-electrician do it while he recharged mine and my son's aircon systems, £110 for the works.
cachaciero
- x 9
Given that the tailgate wiring mod was required on 2001 cars I would have expected that by the time we had got to facelift models that particular problem would have been resolved at manufacture.
I suspect that the problem may be as simple as a duff switch or switch actuator failures of both are quite common.
Of course I could be wrong on both counts
cachaciero
cachaciero
2006 Toyota Prius T Spirit
2001 2.2 C5 Exclusive SE
1996 XM 2.1 TD Auto VSX
1987 CX 2.5 Gti Turbo II dead
1984 Ford Scorpio
1981 CX 2.4 Pallas Auto
Renault 21
1220 GS Club
Rover P6 2000TC
1984 Ford Scorpio
Renault 21
1220 GS Club
Rover P6 2000TC
triumphtoledo
I was with Citroen UK on motoring journalism type work assignments a few months ago and, while I was there, I photographed the tyre pressure sensor changing procedure being performed on my own 56 plate Exclusive estate. I also asked the technicans about the S2 C5, including the tailgate glass.
I was told that the earliest cars used to open their tailgates randomly; it even happened on the C5 UK launch! This was caused by not only the switch being too sensitive but also the wires used to short circuit, due to water creaping in. The cure was to apply a seal over the wires, which can be seen when you open the glass and look along the bottom.
The non-opening can be due to the wires breaking and I believe this problem is carried over on the S2 from the S1. There is a DIY fix on the T'interwebnet.
Hope this helps.
Rob Marshall
Hope this helps.
Rob Marshall
den169
Well known fault i have the instructions on how to repair this for nothing(if its the normal fault)Email me on [email protected] if you want it.Edit just noticed its a 56 plate don't know f its the same problem with facelift models.
tramnut
Thank you all for your help I will try as soon as the weather stops freezing my fingers and dangly bits!
tramnut
tramnut
seroyen
Hello there,
Is this what you are looking for?
http://users.skynet.be/sky83161/sven/openingc5.pdf
(Instructions to fix rear window)
Good luck
Good luck
- x 5662
seroyen
- x 5662
Yes, I realise that but you can still post the link, as long as you don't claim ownership.seroyen wrote:Hello there and thanks for the heads up!
However those are not my instructions!I stumbled upon it on Google while trying to find instructions on how to separate my rear door trim.
Hope it has been useful though!
