Serious Suspenson Fault
marshall
Unread post by marshall »
I have a Citroen C5 2.2 HDI (2002). 2 weeks ago whilst sat in the car I lowered the suspension to 'normal'. Since then i have been unable to higher the suspension and now i have a warning saying 'serious suspension fault' and when going over potholes or speed humps the experience is very uncomfortable. Seems to be only the back end that has been effected. Can anyone shine any light on why this may have happened? cheers ;)
woodywoodpecker
Re: Serious Suspenson Fault
Unread post by woodywoodpecker »
marshall wrote:I have a Citroën C5 2.2 HDI (2002). 2 weeks ago whilst sat in the car I lowered the suspension to 'normal'. Since then i have been unable to higher the suspension and now i have a warning saying 'serious suspension fault' and when going over potholes or speed humps the experience is very uncomfortable. Seems to be only the back end that has been effected. Can anyone shine any light on why this may have happened? cheers ;)
Marshall,
First thing to check is the height sensor linkage rod has not come off the sensor, have a look at the rear antiroll bar to see if the linkage is still connected.
mooseshaver
Unread post by mooseshaver »
Sticky brakes can be a cause of this too.
Gone cars.
C3 1.4 HDi 92 SX 52.
Saxo 1.1 East Coast.
cachaciero
x 9
Unread post by cachaciero »
First question is does the pump run? You should hear it run when you unlock the car or put the suspension in high. If the pump doesn't run check the maxi fuse under the engine relay unit.
cachaciero
2006 Toyota Prius T Spirit
2001 2.2 C5 Exclusive SE
1996 XM 2.1 TD Auto VSX
1987 CX 2.5 Gti Turbo II dead
1984 Ford Scorpio
1981 CX 2.4 Pallas Auto
Renault 21
1220 GS Club
Rover P6 2000TC
marshall
Hi there no pump noise, cant get under car to have a look for rod. Seems to have gone down even more. Local garage got no joy on Diagnostics either!
cachaciero
x 9
marshall wrote:Hi there no pump noise, cant get under car to have a look for rod. Seems to have gone down even more. Local garage got no joy on Diagnostics either!
If the pump isn't running check the MAxi Fuses.
cachaciero
1984 Ford Scorpio
Renault 21
1220 GS Club
Rover P6 2000TC
