206 dashboard lights for automatic transmission
panmecheng
Unread post by panmecheng »
Hi all I'm new to the forum. On a Peugeot 206 with automatic transmission the two lights on the dashboard start flashing with the engine running. Thsese are the light with a snow flake on it and the other has an S on it. I had a look on the owners manual and it says that when these two lights appear then there is a problem with the automatic transmission. Ok, but what is this problem? Does anyone know or anyone can help?
spider
x 77
Unread post by spider »
Welcome :)
Yes, you are right when that happens it indicates a problem of some kind.
Does it drive nicely ?
Unfortunately, the only way to find out 'why' is to have it connected to a Planet diagnostic (possibly the Citroen Lexia could be 'tricked' into working too)
It may be nothing though, perhaps just a bad signal at one stage caused it, but it is well worth having it checked as soon as possible to avoid any expense down the line.
Its possible a member from here may be able to help you. You may wish to quickly scan read through these two topics:
http://www.frenchcarforum.co.uk/forum/v ... hp?t=29178
http://www.frenchcarforum.co.uk/forum/v ... hp?t=26807
Andy.
P616VKX
Unread post by P616VKX »
A friend of mine used to have a Xantia HDi Automatic and this same fault was caused by someone spilling coffee on the Sport/Snow Buttons.
It never caused him any problem, in fact, it was the nicest driving car ever!
B564PLC - Red/Grey Renault 11 GTL 'Premiere'
