water damage to rocker cover
daz1968
hello i have just bought a pergeot 306 02 plate 70,000 miles good looking motor. checked under the hood and noticed rust around rocker cover also there is a thick rubber seal which i prized back and more rust where the cover joins the engine what could this be cheers .
panason1c
spider
- x 77
The later ones (I'm assuming its a 1.4 or 1.6) , the TU rocker covers do seem to rust.
The seal sounds like its gone hard, simply replace it. Clean the baffle plate out while you are at it (it will fall out when you take the rocker cover off anyway)
Andy.
- x 1240
