Cold weather niggles
Stepto1
My Xantia 1.8 16v starts great in the cold weather but my steering is really heavy and jerky till the car really warms up. Is this normal? I guess it's because the LHM oil is cold. Also my nearside door mirror doesn't defrost at all while the offside clears in no time. Any ideas?
Kind regards,
Stepto.
Kind regards,
Stepto.
citroenxm
- Fallen Hero
- x 70
RE: Door Mirror. The heated element behind the mirror could be broke, or less likely on passenger side, a broken wire between the door and pillar. But more likely to be the mirror glass...
Heavy steering. This can be because the LHM is due a change, system flush with Hydraflush, and re-fill with new LHM.
My HDi Xantia is currently like this, and needs the LHM changing.
Paul
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
Stepto1
- x 1240
citroenxm
- Fallen Hero
- x 70
As said before Peter - Very Rare on 5 ridged Poly belts...
Certainly ones that have the auto tensioners on them, because these are Bloody tight...
Most likely poor LHM
Paul
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
red_dwarfers
- x 58
- x 1240
Stepto1
falling-out-with-my-car
- x 25
woke up to minus 10 degrees C this mornning this temperature stayed until about 2pm my 50/50 mix of diesel and vegetable oil froze in the fuel lines.
yes it is thourgherly dewatered and filtered right down to 1 micron, got the car started eventually preheating the plugs several times before starting, I am learnning albeit the hard way.
Stepto1
- x 25
it has never in the 12 years i have lived here been minus 10 C
citroenxm
- Fallen Hero
- x 70
Yes Peter, I know that from the V6 12 and 24v's, and the SED as the Pump is on a V belt, and the altinator on a 5 Ridge Belt... untill the 2.5 came along, However, Ive a customer with a 2.1 N reg estate VSX, with a Xantia Setup, with anti sink... IE: Single 6 ridge belt and LHM pump down by the oil sump.Peter.N. wrote:Keep forgetting about them Paulthe XM ones slip for a pastime.
The only 2.1 Ive seen like that, with Bosch Mchanical fuel system.
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
Citroenmad
- x 110
It has been -8 almost all day today, we had no running water all day at work and the heating wasn't working. Really looking forward to the same tomorrowfalling-out-with-my-car wrote:it has never in the 12 years i have lived here been minus 10 C
My C5 has been no problems though, battling through the ice and snow admirably and warming up in no time, giving me a nice warm interior within a few minutes.
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
03 Seat Arosa 1.0S
- x 1240
Stepto1
