Car Snow Clearance
Yes, place your time and money saving tips here.Nothing illegal or dangerous please!Motoring related only please.
ACTIVE8
x 6
Car Snow Clearance
Unread post by ACTIVE8 »
If your car is covered in snow as mine is, and yes I have to get out later, which should be a right laugh with the way others do not cope with the snow.
Then if you are trying to clear the snow off the car, and at the rate its coming down it should be a long job, which I am not looking forward to, so to save time I will get that new soft brush we just bought for the house, it has not been used (which is a point to remember, as you do not want to damage the paint with a brush that's got muck on it.)
It should save time in clearing it, and make it easier to clear, although it might have to stay in the car, as this snow is not letting up!
Also so many drivers clear nothing, and then drive with off with the lumps of snow dropping, and flying off their car which is a hazzard to other drivers, and illegal if they have not made an attempt to clear it, and ensure that they can see out, watch out fot the type that only clears a tiny patch in front off their eyes. :evil:
ACTIVA
x 5673
I buy a new 'snow brush' each winter.
When the snow is gone it gets allocated 'other tasks' and is ruined by the time the snow faeries visit again.
No snow here though. Brilliant sunshine and + degrees. (Not + much mind) :(
Gingerposer
x 6
Unread post by Gingerposer »
I keep an old extendible window cleaning pole, which has a double sided head on it - one side sponge (unused) and the other side with a rubber squeegee - the reach of the pole means that even for a shorty like me, no need to struggle to reach to the middle of the windscreen to clear the snow off!
Different matter with ice tho cos you can't scrape ice off with it. :?
ACTIVE8
x 6
O.K. got the worst of it off, and now have sorted out the travel version, which will be the new dust pan, and brush which will go in the car, and not take up too much space. The pan can scoop the snow off, and the brush can dust it off, :wink: and like myglaren said I will be keeping this for the car, and it can migrate :wink: back to the house when the temp goes up, although the stories in the news, say this cold snap could be with us for a while, apparently for a month.
Although the snow fall seems to be falling in different amounts, depending on where you are.
ACTIVA
x 5673
Gingerposer wrote:I keep an old extendible window cleaning pole, which has a double sided head on it - one side sponge (unused) and the other side with a rubber squeegee - the reach of the pole means that even for a shorty like me, no need to struggle to reach to the middle of the windscreen to clear the snow off!
Suspension on LOW!
I can't reach the top centre of my screen otherwise.
For ice I chuck a bucket of cold water over it - while warming the engine and the blower on "Screen Clear".
I have seen one of my neighbours pouring boiling water straight from the kettle on her new Megané. Rather her than me :?
Gingerposer
x 6
Even with suspension on low I struggle to reach the middle of the screen without resting the lads on the cold bodywork!
ACTIVE8
x 6
Suspension on LOW!
That throwing hot water onto a windscreen is such accident waiting to happen, more so with these glued in screens which are now structural, unlike earlier screens that were not bonded in previously.
ACTIVA
andmcit
x 30
Unread post by andmcit »
Pouring lukewarm water works and can be done safely.
Disaster if it's done with hot or boiling water for sure, though I've always
found the most tepid of water does the trick and clears the screen far more
effectively and quickly than scraping the glass or using spray cans. Really
anything above freezing works just so long as it it doesn't freeze on pouring
- I'd liken it to the effect of sun warming onto the frozen glass after moving
the car out of the shadows where the temperature jump isn't too big to stress
the glass and fracture it.
Andrew
Trainman
(Donor 2018)
x 43
Unread post by Trainman »
I was given a great tip the other day, for defrosting the windscreen, a hot water bottle on the dashboard, simples........ :roll:
Steve
http://c6owners.org/index.php
ACTIVE8
x 6
Trainman wrote:I was given a great tip the other day, for defrosting the windscreen, a hot water bottle on the dashboard, simples........ :roll:
Have you actually tried this out, and if so how long did it take?
ACTIVA
red_dwarfers
x 58
Unread post by red_dwarfers »
Best to have a couple, most of my screen is defrosted in about half and hour but it all depends on quantities of frost really.
Kev
'19 C4 Cactus 130 Flair
DickieG
Monaco's youngest playboy
x 38
Unread post by DickieG »
I'd be mindful of protecting the surface of the dash, freezing cold to very hot quickly, sounds like the recipe for a large split on the dash.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
Citroenmad
x 110
Unread post by Citroenmad »
My preferred method of defrosting is:
- Brush off snow with soft brush
- Use fan heater to defrost around door seam and door handle
- place fan heater on back seat, leave for 20 minutes
- Remove fan heater
By this time the car is defrosted and the interior is warm too.
Though its always an extra thing to do on a busy morning. So whoever is out first in the morning i put their cars in the garage so there are two less to defrost and its faster to get out on a morning. Usually im out first so mine is garaged.
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
x 5673
No half measures:
