anyway of getting round the immobiliser on a xantia ???
imperial21
Unread post by imperial21 »
I am breaking a 1995 vsx and i dont have the code for the keypad anyone know a way round it ?
1111 does nt work.
i have looked at the keypad and have seen wear on 2 buttons otherwise cant see anymore :(
anyone have any ideas ?
1999 Xantia exclusive 110BHP !! Now RIP !!
2002 C5 estate 110 hdi, Happily sold on !!!
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
Unfortunally I dont think there is... Once you know the code, you can disable the keypad, there fore unlocking the ECU...
But while locked, you need the code first before you can do anything else first.
PAul
A very sad...
1994 XM 2.1 d auto
Xaccers
x 188
Unread post by Xaccers »
Didn't think 95's had the keypad or immoiliser, I know mine didn't.
Check if the pump is actually armoured, if not you may be able to remove the immobiliser bit from it and wire up a 12v feed to the stop solenoid
DIY sphere tool
Deanxm
x 87
Unread post by Deanxm »
yep, the only way around it is to fit an ecu with a known code, send your ecu off to be decoded ££££££, fit an ecu from a car with no keypad immobiliser, or remember or find the code obviously :lol: .
What do you want to start it for? has it sunk yet too?
D
XM Prestige PRV6 92
Mitsubishi L200 Trojan 14
citroenxm
Fallen Hero
x 70
Is it DERV Xac?? :wink:
DERV;s didn't have keypads but petrols had keypads from the off!!
Paul :lol:
A very sad...
1994 XM 2.1 d auto
Xaccers
x 188
Ah that would explain things, only had one of those "petrol" dohickies since '97
DIY sphere tool
Deanxm
x 87
:lol: its an 8v petrol he's got
D
XM Prestige PRV6 92
citroenxm
Fallen Hero
x 70
Knew it was a petrol of some sort, as TD's didn;t get them till late 96 to 97...
PAul
A very sad...
1994 XM 2.1 d auto
spider
x 77
Unread post by spider »
Some specialists may be able to unlock and or remove said code from the ECU for you.
But has already been said, with petrol engines you cannot really disable it until its already 'green' , then you can unplug the keypad and ignore it.
If you can find an ECU from a car with an identical engine and electronics without keypad (it might be possible) you could do a straight swap. This was possible on 106's when they first had a keypad around 97 you could get one of the earlier ECU's (if you were very lucky to get the right one) ;)
A replacement ECU from the scrapyard with code might be another option.
A final idea is to contact these people , they seem quite helpful > http://www.alarmremotes.co.uk/products.htm , I would ask them what they can do for you, worth a phone call / email at least.
Andy.
citroenxm
Fallen Hero
x 70
HANG ON...
Ive got a 1.8 8v ECU with known code, I took out of a P reg Estate, I did a DERV conersion with.....
Im sure its in the shed somewhere.... :?
Paul
A very sad...
1994 XM 2.1 d auto
imperial21
as luck would have it i worked the keypad code out by the wear on the buttons !!!
out of interest how do you unlock the ecu permantly ? i have disconnected the keypad while the engine was running !
citroenxm
Fallen Hero
x 70
Then its done !!
DO NOT re connect the keypad... switch engine off, then start again then stop then start, as many times as you like...
Throw the keypad away, and place the original odments try in its place..
Paul
A very sad...
1994 XM 2.1 d auto
x 8417
imperial21 wrote:as luck would have it i worked the keypad code out by the wear on the buttons !!!
Well done! Excellent!
On the second point, there's some very clever people around but they don't share the methods they use.
It cannot be done with a Lexia so they must get right into the machine code of the ECU.
x 1466
Unread post by xantia_v6 »
CitroJim wrote: On the second point, there's some very clever people around but they don't share the methods they use.
There is a box you can buy that just cycles through all the possible codes, it senses when the ECU is unlocked and displays the last code it entered. It is usually used for unlocking transponder ECUs (e.g. Mk2 Xantia).
spider
x 77
Do you have remote locking ?
Its possible on most PSA (but not all) to program it to give 30 seconds or so after unlocking with the remote (does NOT work if you use the key in the door) with a green light.
Although if you have unplugged keypad (all you need to do once its green) that's enough.
Do not throw away as sometimes, if your battery is disconnected, when its reconnected the ECU will be in a locked state, you will need to plug in keypad, enter code, unplug when green light on. Some seem to suffer with this and some do not. Although to be fair they should go back to 'red' / 'lock' if the battery has been off.
Jim, yes that's correct. Although I do not know what specifics are used for this, probably a FPGA custom chip unfortunately, now if it was a straightforward Z80 or 6502 and the ECU program itself in a rom (or eprom, even better) that would possibly be a different matter ;)
Andy.
