Citroen GS - Air intake control valve
chrisn
Unread post by chrisn »
Hello to all,
I'm new to the forum, having joined at the suggestion of a serial Citroen owning friend. Back in August I aquired a nice GS for use as my everyday car, and have so far led a charmed life with it in terms of lack of things going wrong/ breaking/falling off.
However, the recent cold weather has highlighted the fact that the air intake control valve has ceased to function, causing carburettor icing. The actual mechanism seems OK, it isn't seized, but it is no longer being actuated by the thermostat.
Has anyone experienced this before, and is there a solution which doesn't involve a new thermostat, which AFAIK, are no longer obtainable.
Thanks,
x 1496
Hi Chris - welcome to FCF.
There are not that many GS ers here, but some have experience going back that far :lol: I have memories of getting mucky watching my Dad swearing at GS's in the early 80's 8-)
This is probably a case for a bodge - can you not disconnect the thermostat, and then wind the setting to cold - it won't matter this weather- just set it back to cold in the 'summer'!
Let's see some pics of the beast!
x 94
Unread post by citronut »
hi and very welcome as a G owner
is this a GS or GSA, as i think the GS had a manualy operated flap in the air intake,
if its a GSA i have probably got some second hand air filter houseing's with said thermostat atatchet,
were about are you,
im in St Leonards on sea East Sussex,
regards malcolm
chrisn
Thanks for your replies Richard & Malcolm,
I think that in the short term the quick and dirty solution of disconnecting the failed thermostat and moving the valve to the closed position will do the trick.
However it is nice to have everything working as intended, so Malcolm, if you do have a spare thermostat kicking about I could definitely make good use of it. I'm up in North Yorkshire, but will happily pay for postage etc.
The car is a 1979 GS Club, and as requested here are a few pics:
Citroening
x 19
Unread post by Citroening »
Very nice indeed...you can't beat a nice GS! 8-)
Franklin
addo
Sara Watson's Stalker
x 95
Unread post by addo »
What's the rubber - Nankang or the real deal?
hattershaun
(Donor 2022)
x 4
Unread post by hattershaun »
Hi Chrisn,
Very nice looking GS you have there, I'm sure you're proud to own that, I would be.
I recently acquired a GSA and have had 3 GSs in the past; a 1220 Estate, a 1976 1220 saloon & a Birotor, as well as another GSA in the dim & distant past.
You may well have come across www.Chevronics.co.uk, they specialise in GS(A) and keep parts.
All the best with your carb flap.
Shaun
C6 3.0 HDi Exclusive - 2010
SM 3.0 - 1972
DS 23 Pallas - 1975
GSA Pallas C-Matic - 1982
chrisn
Thanks everyone for your kind comments, if a car could blush it would probably do so!
In the photos its shod with Michelins finest. However, due to the weather conditions we've had recently, and the fact I live some distance from a main road, its now on Vredestein 155x80x15 Snow tyres!
Hattershaun: Sounds like you've got a g series fetish going on there, can't say I blame you! Rather envy you the Birotor! I have had a few things from Chevronics before, oil filters & HT leads mainly. They'll probably be getting a call about this before the weekend.
All the best,
andmcit
x 30
Unread post by andmcit »
The G is a truly superb car and I'm genuinely thrilled to see yours in such
fine fettle and running merrily in the way only a happy G can! The colour
has to be my favourite for these being the exact same as my EFJ522T,
a 1222 GSpecial my first car / Citroen over 20 years ago now but sadly
gone. It easily besotted me into becoming a long term Citroen fanatic and
is the reason I still own several today, including two LHD 1973 cars from
France among a wide selection of other Citroens.
I got so paranoid and nervous should anything nasty accidentally befall one,
I stopped using them as daily transport. :oops:
It's great to see these pictures, it's too easy to forget just how fabulous
these cars look when you don't drive them regularly, thanks!!
Andrew
x 94
stunning looker (no the car),
if you pm me your details i will dig one or two out, is there any other bits and bobs you are after,
regards malcolm
x 5674
That looks to be in exceptionally fine condition. They are a truly remarkable car. My first Citroen was a GS 1220 club. S-reg. Used to eat driveshafts for fun but was a superb ride.
davewithington
Unread post by davewithington »
That is one gorgeous GS.
Never had one in French blue - both mine were Geranium - but it was always a favourite.
Keep it out of the salt though, they do'n 'arf rust.
