cheshire C5 owner
signmaker61
cheshire C5 owner
Hello all. Keith in cheshire signing up due to misbehaving C5 2.2 diesel. Already found some good advice so thanks to those contributors.
Citroenmad
- x 110
- x 8444
signmaker61
Thanks chaps.
Like a few C5 owners, I think that, underneath the baffling array of faults, there's a worthy motor car desperate to get out.
Thus far, in the 5 months I've had it, I've had the anti-pollution warning every couple of days, ESP warnings, diesel additive warnings, limp mode on a regular basis, poor low-rev torque, rear tailgate strut failure (causing several bangs on the head) and the front passenger window which comes down about 3 inches when I put the wipers on. True. Apart from that, it's been fun fun fun all the way
On the brighter side, my local indy garage might have solved the APW/ESP/limp mode issue having found a split vac pipe. And I've transported tons of stuff around without having to hire a van.
I'm getting a new Berlingo van in Jan with my job so it's bye bye C5 by the looks of things.
Citroenmad
- x 110
Thats right, the C5 is a great car, I love mine. They do have a few niggles but on the whole the are very good cars.
In truth the 2.2 isnt a bad engine, the main problem is the FAP filter and Eolys fluid which can cause the antipollition and limp home mode problems. Usually this requires a top up of the fluid and a clean of the filter. I think it can even be disabled.
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
03 Seat Arosa 1.0S
signmaker61
Did I mention that I've had a new FAP filter fitted and topped up the additive? (the ECU has been reset but it still tells me it's at minimum level - and at
£35/litre, that's not what you want to see.) And I've had a new (used) intercooler fitted because the other had a hole in it. And the car shudders at between 70-80 mph despite the centreless wheels having been balanced. Stop me if this is getting boring.
