berlingo no screenwash or dash functions
jimbofz
Unread post by jimbofz »
Hi just to clarify re my original post dated 5th dec
the dash functions dont work except the oil light comes on in ignition mode [as it should] and goes out when start up [starts first time even in this weather]
can anyone tell me if theres a different reset on these early models,
its a 2000 x reg?
under the internal fuse box lives the bsi module i have looked to see if theres any water ingress ,and it all seens fine
although the ins book shows pic of fuse box,there are quite a few differences,ive tested fuses and voltages with digital meter and all seems ok including the 6 fuses on bsi module and engine bay fuses ,i have unplugged the 2 pin plug to the screenwash reservoir[under inner wing,and to my surprise there is a short cct to earth on the two wires !! purple and grey
even with the motor disconected, i traced these wires round the bulkhead and inside passenger footwell
cant understand why feed to screewash motor is short to deck
ithink if i can find the short then my dash should then also work
any ideas would be more than welcome thanks
