Washer jet heaters
x 1507
Washer jet heaters
Right, I've had enough of frozen washer jets :twisted: The tank is still liquid, but the jets freeze even at / around 0°C - not that it would have helped this morning when it was -15°C :roll: I thought about perhaps fitting a set of pucker of heated nozzles, but looked them up and they are £75 a set, so scotch that idea :lol: So, 2 ideas: run a hosepipe from the back of the rad up to the scuttle to duct some warm air up; or strap a resistor to the nozzle and wire it into the side light circuit - 150 ohm should give about 1W dissipated heat, so that ought to be enough.
Any thoughts?
More here if I get it to work!
Where are the heated nozzles normally fed from - the HRW circuit? Is the wiring likely to be there in the scuttle?
the_weaver
Unread post by the_weaver »
Richard
I've heard about people wrapping the screenwasher pipe three times around the water pipe that goes to the heater, at the bulkhead. I don't know if it works or not.
A bulb might work as an alternative to a resistor. You could paint it black. Maybe they do nozzles with bulbs in them. LED's would not be warm enough though.
There's also something called resistance wire, or Nichrome heating wire. Maplin might sell it. You could wrap some of it around the pipe close to the nozzle. An inline fuse would be a good idea if you're experimenting with it. I think an old type wire-wound power resistor might be a few turns of Nichrome wire wrapped around a former. Maybe you could extract the coil from the former and place it around the washer pipe. If you removed the former you'd probably have to reduce the power capacity though, as I expect the former acts as a heatsink. Most heating elements use Nichrome wire. If you've got an old, blown element from an electric fire or cooker then you can get some wire from that.
Paul
addo
Sara Watson's Stalker
x 95
Unread post by addo »
Mine has the plug tethered in the scuttle, just behind the inertia cutoff - think it's black.
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
XM's have them as standard, but rarely work.... :D
They are fed from the HRW circuit along with the Door mirrors, on XM's that is... Im surprised the Xantia even exclusives arent heated...
Paul
A very sad...
1994 XM 2.1 d auto
Chris570
x 36
Unread post by Chris570 »
citroenxm wrote:XM's have them as standard, but rarely work.... :D
Paul
They are if you had the winter pack, both of mine mine do :)
2006 C5 HDi 170
1998 Xantia Activa S1
1971 D Special
2018 Renault Zoe,
CitroJim wrote: I'm a pink fairy
A 1/3 of Team WFA 'Clarkson'
HDI
x 7
Unread post by HDI »
Ah, so thats why some Xantia exclusives have cold weather heaters and some don't, there was a cold climate pack !
Mine has heated jets but it's waste of time because the tubing from the reservoir freezes up and takes at least 30 mins to defrost on a sub zero day ! I keep intending to try insulating foam jacket around a polyurethane tube, PVC is hopeless in very cold weather as it will split and remain kinked if sharply bent. Another idea would be trace heating cable wrapped around the tubing, this is commonly used in industry to prevent fluid lines freezing on remote plant.
Now using '00 Xantia LX HDI, pov spec :(
My past Citroens :-
'00 Xantia SX HDI, now dead due to accident :(
'99 Xantia HDI 110 Exclusive, RIP :(
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
'79 CX2400 Pallas (scrapped :( )
& a couple of Peugeots !
Chris570
x 36
i just increase the % of screenwash in the bottle before we start to get cold and it isnt a problem
2006 C5 HDi 170
1971 D Special
2018 Renault Zoe,
x 8468
Chris570 wrote:i just increase the % of screenwash in the bottle before we start to get cold and it isnt a problem
Or do as the Russians do and fill the washer bottle with Vodka. It has a very low freezing point...
jimleshed
Unread post by jimleshed »
What a waste of good vodka! Hmmm, must check my sloe vodka, its rolling around in the boot at the moment!
Jim Le Shed
Citroen C5 2.2 HDI Exclusive
Mazda RX8 231PS
Past history...
Mazda MX5
Renault Lagunas (3)
Peugeot 405, 205
Citroen CX's (5)
Citroen GS (lots of other Cars and Bikes too!!)
citroenxm
Fallen Hero
x 70
AH HA! The answer at last to the "Unknown Fuel Heater Burner!!!" that Ive never seen yet..
I knew it WAS NOT fitted to my car and my mates car! As discussed else were in a thread...
Paul
A very sad...
1994 XM 2.1 d auto
Chris570
x 36
as seen in the top gear driving on an active volcano film :)
2006 C5 HDi 170
1971 D Special
2018 Renault Zoe,
x 1507
Didn't we decide that the aux heater was an option by itself, rather than just the winter pack...??
Some interesting thoughts guys. Running near neat concentrate, but it still damn well freezes in the nozzles. Maybe I need another brand!
Citroenmad
x 110
Unread post by Citroenmad »
Hmm, so not all Xantia Exclusives have a pre-heater then, I thought they did. So a winter pack on those brought heated washer jets and a pre-heater?
Im guessing C5s have heated washer jets, as ive not had them freeze as yet, even with -10 temperatures.
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
evilally
x 3
Unread post by evilally »
I've been putting a good helping of alcohol into the washer bottle with my usual screen wash mix, been working fine! Although it does smell a bit when you wash the screen!
'97 406 1.9TD, 314k.
mooseshaver
Unread post by mooseshaver »
Citroenmad wrote: Im guessing C5s have heated washer jets, as ive not had them freeze as yet, even with -10 temperatures.
My rear one freezes often, and sometimes the front, so my VTR cannot have them. And on a trip through freezing fog, at the top of the hill I used my screenwash, it froze on the windscreen, (temp -5) then melted at the bottom of the hill (-2). I'm guessing my mix of anti-freeze is not as strong as yours
Gone cars.
C3 1.4 HDi 92 SX 52.
Saxo 1.1 East Coast.
