berlingo deisel 600 van after flat battery no dash functions
jimbofz
hi can anyone help please,berlingo 2000 year van ,battery went flat while i was in hospital ,i recharged overnight on trickle charge ,van started but no dash lights , screenwash?or indicators,i found out about the 3 minute rule on a forum ,this made no difference except the oil led flased on ,so no info on dash about temp or revs ect.the van starts up fine now so battery holding its charge ok javascript:emoticon('Crying or Very sad') has anybody had same problems?
- x 1443
jimbofz
berlingo dash
Hi and thanks xantia v6
sadly ive tried this ,my big mistake was to remove battery to charge overnight in shed ,should have left in situ ,i think with no batt connected the bsi or computer has been discharged and now has to be re set ?
- x 94
hi and welcome
i have read somewere not spesific to the berlingo but regarding ECU/BSI memory's,
when disconecting the battery you should not opperate anything, including door's, bonnet or boot lid,
as this allows the medmory's to reset fully,
you might need to have it hooked up to a LEXIA,
regards malcolm
regards malcolm
jimbofz
- x 94
if you go to the supper sticky section on this forum you will find a map of who and were we members own DIS LEXIA's me being one but im on the south coast,
a lot of members only charge a cup of tea and chocy bicy's,
i do charge £20 quid as i run my own car repaire shop
and yes the LEXIA is last generation citroen diagnostic tool,
regards malcolm
regards malcolm
jimbofz
