205 Sagging door
cheesesliceking
205 Sagging door
Unread post by cheesesliceking »
Helloo!
The wifes 205 drivers door when shut looks to be sagging a bit it doesnt line up right with the bodywork grooves etc.
N E Ideas ppl??[:)]
Cheers
JohnD
(Donor 2022)
x 72
Unread post by JohnD »
You'll need to examine the door and hinge and decide where the movement is coming from. The hinges are welded to the body on one side and bolted to the door on the other. Check the weld on the body and also the bolts for tightness on the door. If those two points are OK, see if there is movement in the hinge pin. The pin is removeable, and if it's worn, could be replaced.
cheesesliceking
Thanks matey I'll givce it a check [:)]
