Berlingo brake regulating valve.
HFF
how do I free the brake regulating valve on a berlingo, the arm appears not to move.
spider
- x 77
This is not that uncommon, 206's also seize.
Spray it in penetrating fluid especially around the pivots and work it as best as you can, usually a pair of grips (careful to not bend the arm if its really seized) to work it.
If its really bad you may have to use a pry bar etc to initially move it, although that's not a common occurrence.
Obviously you need to be careful not to damage the valve itself.
Andy.
spider
- x 77
