Laguna cold starting problem
Max Manners
Unread post by Max Manners »
Hi my Laguna petrol automatic 2L fires on 2 or 3 cylinders, very lumpy when I do a cold start but whne warm is okay, please tell me the solution? Max
Chell
Unread post by Chell »
Hi, This could be due to a number of things. i.e HT leads, faulty spark plugs, or worse case senario head gasket. It might be worth checking if there is excessive pressure in the coolant expansion tank.
Hope this helps!
bongo
Unread post by bongo »
could be the coil pack, sometimes fail when cold but work ok when hot and a common failure
David Goddard
Unread post by David Goddard »
As the engine is running OK at operating temperature, it could be the engine temperature transmitter. If this is shorted out, the engine thinks it's hot when it's not. The mixture will be too weak for a cold start and will run badly.
Cost about £13. Can be tested easily tested with a meter. On citroens they are Green and have the following characteristics - 4,600 ohms at 0 degC., 2,800 ohms at 20 degC., 150 ohms at 100 degC.
Simple to change.
gord247
Unread post by gord247 »
i would try your cold start sensor should cost you about £18.00 plus vat will take you 10 mins to fit with a 19mm socket
