xantia door handle, d/s
wornelly
Unread post by wornelly »
anybody any diagrams on the door lock mechanism for my 97 xantia, door opens drom inside but not the outside any ideas, thanks,
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
Ah, the common weakness of a design..
The likely thing is the Rod that the outer handle pushes down - attache's to the lock lever by a sort of crockadile tooth type clip, has likely slid down as the spring side has got weak with age...
Its a VERY damm awkward place to get at and set up correctly... Its an all in one rivited job so not easilly replaced on its own..
Someone will have the diagram, Ive not got access to any exploded diagrams :cry:
Paul
A very sad...
1994 XM 2.1 d auto
wornelly
door handle spring
anybody know of any replacement parts that i will need, or just the whole handle, ???
andmcit
x 30
Unread post by andmcit »
It's not the fault of the actual door handle on the outside of the door or for
that matter the inside either, but as Paul says, the central locking cassette
that is triggered by the rods that operate the mechanism. You can try taking
it out of the door and repairing it but at that stage you're better off just
bolting a better alternative one in from eBaying one. Guy I've dealt with
called 'Hand shandy" is highly recommended and lists one for £20.
You say drivers but don't say if it's front or back door or whether it's a
saloon or estate if a rear door - all are different and handed.
They're a pita to do especially setting the teeth of the grip Paul describes
as the crocodile and correct adjustment is critical.
Andrew
wornelly
door handle
it is the drivers door, and i am watching one on ebay, but it someone called dksalvage, if you can find the listing you found could u possibly email it to me, thanks, wornelly at ntlworld dot com, cheers
wornelly
fixed
Hi, it's fixed just took me some time to get round to it lol, quite an easy job just hope it keeps working, thanks
