1998 Espace Immobiliser
JimS
Unread post by JimS »
Morning,
Is the immobiliser linked to the fuel pump on my 1998 Espace RXE. The immobiliser light does not go out since I had a new fuel pump fitted last week.Before that it was working ok.
JimS
Got the answer from the garage who fitted the fuel pump.I knew they had put a second hand pump on(which has warranty).The Espace does not reconise the pump as it was on another vehicle.So it thinks it has a immobiliser fault. But it makes no difference to the actual working of the pump.You can send the pump away to have it programmed to your vehicle.If a new pump is fitted it will be programmed to your vehicle.You live and learn.
Jim :D
