406 service light
x 1240
406 service light
Unread post by Peter.N. »
Hi Folks
Can anyone tell me how to put out the service light on a 110 Hdi?
Deanxm
x 87
Unread post by Deanxm »
you have to service it Peter :lol:
being psa i would guess you have to hook it up to a diag or similar to turn it off, i may be wrong though
D
XM Prestige PRV6 92
Mitsubishi L200 Trojan 14
Toby_HDi
x 3
Unread post by Toby_HDi »
- Press and hold the zero button
- Switch on ignition, display starts counting down from 10, keep it pressed until it finishes.
- You'll see the display flash up with =0 and you're done.
You can also change the service interval. Either 12k or 20k. Same procedure as above but release the button before it finishes counting down, then use the zero button to select the interval you want, then press and hold the button until it completes the countdown.
Toby
Previous:
2004 Peugeot 407 HDi 138 SE Luxury Pack
2001 S2 Xantia HDi 110 SX
2001 Peugeot 406 V6 Coupé
1998 S2 Xantia Activa
2000 S2 Xantia HDi 110 SX
1999 Peugeot 406 2.0 16v Estate
Deanxm
x 87
Thats not very psa at all :lol:
D
XM Prestige PRV6 92
Citroenmad
x 110
Unread post by Citroenmad »
Deanxm wrote:Thats not very psa at all :lol:
D
Ah, not everything is complicated :lol:
I didnt know about the option to extend the service interval counter. I didnt know they were ever on 20K servicing.
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
spider
x 77
Unread post by spider »
I think its because the same circuitry in the odometer part at least is shared between petrol / diesel, hence you can switch it to other intervals.
The older ones (306's for example) you could change them between 6k and 9k (and possibly 4.5k)
Andy.
x 1240
Thanks for that Toby - it doesn't tell you in Mr Haynes book.
Dean
I have, I have :D changed the oil today in sub zero temperature, I shall continue to do it at 5k regardless of what the indicator says 8-) Bought one of those reset thingies for the BMW, only used it once :(
Deanxm
x 87
Your a braver man than me Peter, i wimped out and came indoors! mind you, i bet its the only time of year you were gratefull for having hot oil running up your arm :lol:
D
XM Prestige PRV6 92
Citroenmad
x 110
Braver than me too! I need to service my C5, i was thinking about doing it this morning but with the freezing weather i really couldn't bring myself to do it.
I do mine every 6000 miles, its ready for one now.
03 Seat Arosa 1.0S
x 1240
Having the ramp makes it a lot easier - and I refitted the undertray :D
Citroenmad
x 110
Oh yes, Ive seen pictures of your ramp. It does look quite handy :)
I do mine in the garage on small ramps, wih the car in high there is loads of room but its -6 outside and snowing, i dont really fancy it at the moment :roll: Ill probably do it this weekend.
03 Seat Arosa 1.0S
spider
x 77
I've put off doing a drop link on the front of mine :oops: as it was cold out, now its worse what with about 3 inches of snow ( no garage or driveway :( ) so it will have to wait a bit longer.
I know its only 5 minutes if that (might not even take the wheel off actually) but with it being cold / bad weather it will decide to be one of the annoying ones and spin (hacksaw time) :?
Andy.
x 1240
This is certainly not the time to be doing non urgent jobs but having only recently bought the car, it looked as though the oil had not been changed for some time and I am clocking up the miles, its in pretty good condition at the moment and I would like to keep it that way.
The weather here is not as bad as many of you are experiencing, we have had a little snow but it has mostly gone now - but its not hot :(
spider
x 77
Understand :)
Tis as you say not the ideal time for outside work, but with you just having purchased, it needs doing as you say.
As a usual rule of thumb, I tend to get everything done around October (even if its a bit early) to ensure I do not have to do much over the winter months (certainly till late Jan / early Feb) , although there are exceptions obviously.
Andy.
Citroenmad
x 110
That would be a good idea, though it does depend on when things fail or things need servicing on the cars. My MOT was due before today, so that was last month i got that done, thankfully it didn't require me to do any work.
Its just due a service so i really should be outside doing that, but as i do it every 6K i think i can go a little bit over that until the weather is a little better.
Its been snowing on and off most of the day here, hail too. Its currently a blizzard.
03 Seat Arosa 1.0S
