306 front wipers dont work...please read
evilally
x 3
Unread post by evilally »
Could be the linkages are siezed? Has it been sat for a long time? Give them a good skoosh of WD40 and then a wiggle to see if they start going.
'97 406 1.9TD, 314k.
Deanxm
x 87
Unread post by Deanxm »
Just because the relay is clicking doesnt mean its getting any power, it just means the switch side is, check the fuses and failing that have a check with an avo for power at the motor and work back, its a break somewhere.
D
XM Prestige PRV6 92
Mitsubishi L200 Trojan 14
Deanxm
x 87
yeah sorry, a multimeter, if the motor is good, and the switch is working which it must be as the relay clicks and the washer works then there must be a break in power between the fuseboard and the motor itself.
not the time of year to be without wipers!
D
XM Prestige PRV6 92
