Faults reading using - Lexia 3 , Lexia 3 user manual needed
lancia58
(Donor 2022)
x 8
Unread post by lancia58 »
Hi
I hocked my Lexia 3 to my Xantia 2.0 16V SX ( year make 2000 ) and got the following faults:
For the Automatic transmission ( AL4) I got the following:
Intermittent fault: Display serial supply short to earth ot open circuit
For the alarm system I got the following:
Permanent fault: Remote control buttery discharged
Does any one know how to fix the above faults ? Where is the remote control unit
? I guess once I find it I'll have to replace the battery. Which ECU is not
responding ? I got this message for the air condoning test and the rear mirror
Any one knows where is the Air conditioner ECU and the remote control ECU
Does anyone have the Lexia 3 user manual, I interest especially in the pedal programming procedure ( I have and AL4 gearbox) . Any Lexia's menus procedures I should avoid ?
Zohar
x 1061
Unread post by wheeler »
Normally the engine needs to be running to get comunication with the A/C ecu.
The rear mirrior only has a control unit if it is the indexing one that auto adjusts when you select reverse which i doubt will be fitted to an SX model.
I would imagine the remote battery fauly refers to the battery inside the remote plip you use to unlock the doors ??
x 8468
The AL4 automatic gearbox fault refers to the gear position repeater display in the instrument pod. It works via a serial digital signal from the gearbox ECU on wire 463 between pin 4 of the ECU to pin 15 on the blue instrument panel plug.
Have you noticed any problems with the display? If it seems Ok then I'd be tempted not to worry too much about that particular one...
DickieG
Monaco's youngest playboy
x 33
Unread post by DickieG »
As far as I know there is no manual for a Lexia over and above the very basic functions as almost every car has a different mode of operation within Lexia.
My (genuine Citroen) Lexia 2 has never yet managed to connect with the rear mirror control ECU despite being used on at least six car's that I know have it fitted so don't be surprised at the lack of communication with that one.
As for the other two faults (or any other you find recorded for that matter) don't believe all you see without clearing the faults at least once to see whether they re-appear. You'll also find that some faults are common to certain models, for instance steering angle sensor on Hydractive car's and remote control faults are very common faults to find on Xantia's.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
lancia58
(Donor 2022)
x 8
Hi Jim
Yes I noticed problem with the display , it is very rare but sometimes the snow and sport lights lit for a second. It happened three month ago and since than it haven't happened again. I noticed that when you push the gear lever from D to N and you let the lever stay long enough between the D to N the snow and sport lights blinks I tried it once I guess this is SW bug and not gear fault. The AL4 is OK and I prefer not to "play" with it as long as it is OK ( 75K miles ) . Yesterday I connected the Lexia again and find some other thing that raise questions but I'll post it in a different thread
Zohar
