Does the ECU have a integral cooler?
I have the fault edc16c34_dv6
temporary fault
cooling function integrated into the ECU (fan unit) open circuit or temperature too high.
I can see the fault has been erased many times. Every time its been to a dealer. Is it a real fault or a pretend one?
1.6HDI Injection ECU
mooseshaver
Gone cars.
C3 1.4 HDi 92 SX 52.
Saxo 1.1 East Coast.
Gone cars.
spider
- x 77
mooseshaver
Its too cold today to have a look. I assume the thing must be with other ECUs next to the battery?
Gone cars.
Gone cars.
cachaciero
- x 9
What it is saying is that the engine cooling functionality i.e fan control is integrated within the ECU i.e fan cooling is not in a separate ECU.
In simple words the fan speed is controlled from the injection ECU.
Going on from that it would seem to me that it is seeing on oveheat condition but isn't quite sure why??
cachaciero
cachaciero
2006 Toyota Prius T Spirit
2001 2.2 C5 Exclusive SE
1996 XM 2.1 TD Auto VSX
1987 CX 2.5 Gti Turbo II dead
1984 Ford Scorpio
1981 CX 2.4 Pallas Auto
Renault 21
1220 GS Club
Rover P6 2000TC
1984 Ford Scorpio
Renault 21
1220 GS Club
Rover P6 2000TC
mooseshaver
A pretend fault then? The fan only has one speed, and that works fine on the actuator tests. The low speed does not. I've had the dealers look at this and they told me it only has one speed.cachaciero wrote:What it is saying is that the engine cooling functionality i.e fan control is integrated within the ECU i.e fan cooling is not in a separate ECU.
cachaciero
Gone cars.
Gone cars.
cachaciero
- x 9
It seems to me that ECU believes diffferently I feel sure that the ECU will be able to drive a two speed solution if programmed, so the question is is the ECU correctly programmed for a single speed fan, because if it is programmed for two speed then I guess it's not surprising that it complainsmooseshaver wrote:A pretend fault then? The fan only has one speed, and that works fine on the actuator tests. The low speed does not. I've had the dealers look at this and they told me it only has one speed.cachaciero wrote:What it is saying is that the engine cooling functionality i.e fan control is integrated within the ECU i.e fan cooling is not in a separate ECU.
cachaciero
cachaciero
1984 Ford Scorpio
Renault 21
1220 GS Club
Rover P6 2000TC
1984 Ford Scorpio
Renault 21
1220 GS Club
Rover P6 2000TC
- x 8468
