Laguna II
Sam L
Laguna II
Unread post by Sam L »
Hi all i am looking at a laguna 1.8 16v on a 51 reg and i have a question
when i drove it the clutch seemed quite high but if you put it in 1st and slowly bring you foot out it bits at half way but not when driving it seems alot higher
is this normal or does the clutch need attention soon
thanks Sam
antz
Re: Laguna II
Unread post by antz »
Sam L wrote:Hi all i am looking at a laguna 1.8 16v on a 51 reg and i have a question
thanks Sam
hi, possable clutch master or slave cylinder leaking, if you can check around the clutch pedle for leaks and also around the bellhousing, this may give you a clue to the problem, renault did do a recall on the master cylinder so check if you can that this has been done, hope this helps..
