Would appreciate for someone to take a detailed pic of the original routing for the windscreen washer tube in the vicinity of the drivers side bonnet hinge.
I have a constant problem with the tube kinking whenever the bonnet is opened and closed and whatever route I try doesn't resolve it !
Xantia 2 HDI.
Windscreen washer tube routing ?
HDI
- x 7
Now using '00 Xantia LX HDI, pov spec
My past Citroens :-
'00 Xantia SX HDI, now dead due to accident
'99 Xantia HDI 110 Exclusive, RIP
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
'79 CX2400 Pallas (scrapped
& a couple of Peugeots !
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
Chris570
- x 36
Oh that is annoying, thats the first problem i fixed with mine.
if i remember correctly i followed it down the hinge arm and then put a BIG curve in it towards the rear of the car.
I'll take a pic later for you
2006 C5 HDi 170
1998 Xantia Activa S1
1971 D Special
2018 Renault Zoe,
1971 D Special
2018 Renault Zoe,
A 1/3 of Team WFA 'Clarkson'CitroJim wrote: I'm a pink fairy
HDI
- x 7
Cheers
It really bugs me when I forget to check the washers after being under the bonnet then discover they don't work when needed !!
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
spider
- x 77
VertVega
- x 13
Re: Windscreen washer tube routing ?
I had the same problemHDI wrote:...I have a constant problem with the tube kinking whenever the bonnet is opened ...
but this time hose was disconnected every second or third bonnet opening
Then as a second solution I have added a plastic cable spiral around the hose (also renewed the cable tier)
and that cured the problem.
As usual
I have never heard or seen the same solution anywhere else but it helped and worked many years
Edit: "Cable spiral" is not the correct name for it I guess, Google search gave correct images with the words: "Cable,retention,Spiral wrap".
Main function of it (in my case) was to isolate the washer hose and the car body.
Xantidote
- x 5
The original tubing on my 1995 TD split after 9 yrs, and I replaced the full length of tubing, providing, as Chris says, a good curve of tubing towards the rear of car. It was originally fixed near lower edge of bonnet with a cable tie.
This month, 6 years later, I've had to redo, as the the tubing had split again, but this time, I just cut out the 6-8" of tubing just under the scuttle and replaced it, using 2 in-line plastic connectors - a much quicker job. presumably the tubing hardens with age, and I don't mind redoing the job every 6 years
I wonder if too much tubing curved back under the scuttle could foul up with the wiper drive mechanism?
Martin
1995 Xantia TDLX (deceased
citroenxm
- Fallen Hero
- x 70
From the hinge, the turbo then goes through to the back of the outer wing in the same place all the Wiring harness goes, under the plastic cover... then it goes over the front wheel behind the arch liner and down to the Washer Pump at the front ahead of the drivers wheel...
For people wanting to know...
Paul
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
