Hi, is the steering column the same on the early 1999 models for cars with and without power steering? I was wondering about the extra length of the pinion shaft on the p/s model, but does the telescopic feature in the column cope with either?
Thanks,
Patt.
Saxo steering column
- spider
- My Cars: Soon, I hope...
- x 77
- Contact:
I 'think' they are different, certainly the lower part (if its a two part one)
I don't have my tech data to hand otherwise I could give you a 100% accurate answer.
I do say I think they are different as on a 205 (I know its not the same) the lower column is different for models with / without PAS as I looked into it quite extensively.
Andy.
Cheers Andy. Can't say if it 2 part or not. It seems to have a telescopic sleeve with 2 universal joints further down.
Patt/
Patt/
- spider
- x 77
- Contact:
The lower part will be different then, I can say about 90% sure.
I would be 100% but I don't have my tech data (Pug tech data) but it will match up 106 / Saxo , as I'm slowly recovering from a nasty pc crash last week so don't have that data accessible at the moment.
Someone should be able to look it up for you though, but I'm about 90% sure its different. Ideally you want the complete column to match whatever you have (or plan fitting)
Extra note: The wiring (engine / main power loom) is different for models with PAS, if that matters (depends if you were thinking of adding it I guess, you did not say)
Andy.
- spider
- x 77
- Contact:
I'd agree.imperial21 wrote:Hi
I used to work on alot of saxo/106s i remember they suffered the top bearing failure, i have mixed the 2 different coloums,as it pulls apart, but i think you are better off finding the right coloum.
After thinking again , its (probably) only the lower half that's likely to be different though. But it would be best to get the complete correct one obviously as safety is a high concern with steering.
Andy.
Hi again, yes, it looks like there's 2 different parts here. Better get the right one and be sure. Thanks.
Patt.
Patt.
