It fools everyone!!
The tank can look half empty - or half full if you like - and the float WILL still be on full, this gives owners the false pretences that the float does NOT work, were in fact, there IS pleanty of fluid in the tank..
The float come away on its own, disconnect the two wires, twist the part the wires are unplugged from and lift thefloat out, then watch it DROP!!
Its plain and simply TOO full, theres nothing mechanicaly complex what so ever about the float, its all plastic except inside the top were it drops down and makes the two plugs contact...
Paul
A very sad...
1994 XM 2.1 d auto
