JUST AN UPDATE FOR ANYONE WHO MAY HAVE THE SAME PROBLEM (SEE ORIGINAL AIR CON)
MANAGED TO BYPASS THE AIR CON COMPRESSOR USING A NON AIR CON BELT FOR XANTIA 1.9TD (1130MM LG). THE ONLY DIFFERENCE BEING THAT THE BELT GOES OVER THE TOP OF THE ADJSUTER PULLEY INSTEAD OF ROUND IT SO IN PRACTISE IT PUSHES RATHER THAN PULLS . AT THIS LENGTH THERE IS ABOUT 6MM OF MOVEMENT ON THE AUTO TENSIONER WITHE THE ADJUSTER PULLEY FULLY BACKED OFF. [:)]
