Hello
My driver's side (lh drive) window fell down. I"ve dismantled the door panel in order to gain access to the mechanism and I've found that it was in parts. after looking into it I think that I've found the problem. I guess that due to "modifications" that were made, apparently by some mechanic, the white thing that the two cables attaches to, was repaired with epoxy resin, and I dont find where one cable has to connected. perhaps one of you people has apicture that describes that? alternativly, perhaps you know if and where I can buy that white plastic thing?
Thanx.
Seeking help with Xantia 2001 window regulator
DickieG
- Monaco's youngest playboy
- x 33
electronmirror
- x 30
Hello,
I beg to differ with you DickieG.
I've found a source for these plastic regulator clips on eBay from a company in Turkey. Go on to eBay and do a search for "sesuya".
They sell all manner of window regulator repair parts including these clips for the Xantia. Incidentally the clips they list for the Renault Clio and Scenic appear to be the same as the S2 Xantia.
I've bought from them in the recent past and received the parts within a week of ordering. Price worked out at about £7 per clip including P&P and exchange rate adjustment.
I had previously tried to repair the clip using epoxy resin....it lasted 3 days !
Rgds.
Ted
Rgds.
Ted
Ted
2010 C5 2.0 diesel(163) Exclusive Tourer (135,980miles)
1999 Xantia Exclusive Estate 110 Hdi Mauritius Blue with self peeling lacquer finish (276,174miles)
1991 XM Prestige 2.0 Auto(157,000 miles) gone but not forgotten
- x 8468
VertVega
- x 13
DickieG
- x 33
VertVega
- x 13
You are right it's looong list
According electronmirror, Clio and Scenic clips are same as in Xantia II.
electronmirror wrote:...Incidentally the clips they list for the Renault Clio and Scenic appear to be the same as the S2 Xantia....
atr
- x 6
