Seat belts
guzgog
Seat belts
Unread post by guzgog »
Hi, is there away tensioning the seat belts a bit so they go back in place when you take them off in stead off them hanging down and getting trapped when i shut the door its a c5 by the way. cheers Stan
x 94
Unread post by citronut »
you cant useualy re/tension seat belts,
but you might find pulling it fully out might reveal it has a twist in its length which is stoping it retrackting freely,
or may be something is obstruckting it as it enters the slot in the trim,
you know also this can/will fail a MOT if it does not retrackt readily,
regards malcolm
Clogzz
x 40
Unread post by Clogzz »
Try rubbing candle wax on the underside of the belt where it stops rolling in. :twisted:
Not too much of it by cold weather, a little bit at a time to see how far it gets.
guzgog
Hi guys thanks for the info will try the wax on the belts solution.
cheers Stan
