Have noticed when I start the xantia the glow plug indicator does not light up, even after being stood all night. Is there a way to check all the display lights as turning the ignition on doesn't do it either
Richard
Glow plug indicator
- x 8469
Sadly not Richard, the only way to fully test the bulbs is to have the instrument pod right out and connect each across a small 12v battery. Because it's such a faff to get the pod in and out (easier on a MK2) , I test every bulb I replace, even brand-new ones.
As for the glowplug lamp, if it's an HDi then it's likely that it won't light until the brass monkeys are out in force as a common rail DI engine needs pre-heating only when penguins start to shiver..
The older 1.9TD and 2.1TD IDI engines need pre-heating even when the pavements are melting in the heat so if the lamp is off and yours is a 1.9 or 2.1 and there are no starting issues, you can assume the glowplugs are doing their thing and it's just a lamp... Unusual though as these warning lamps spend so little time alight that they do tend to last a long, long time.
Jaspwieser
OnlineRichardW
- x 1507
spider
- x 77
It only comes on if its really cold.
If you are interested, here are the figures for the DW10 (the 2.0 HDi unit):
coolant temperature -- pre-heating time in second(s)
Summary: Having the glowplug light not work on a HDi is not a concern as long as it does start easily. As above, it will not come on unless its really cold.
- -30°C -- 20
- -10°C -- 5
- 0°C -- 0.5
- +18°C -- 0
As soon as ignition is switched on : The engine management control unit supplies the glow plugs and controls the lighting of the warning light on the instrument panel, depending on the coolant temperature; The pre-heating time varies depending on the coolant temperature .
NOTE : the warning light on the instrument panel only comes on during the pre-heating phase; it comes on for the duration of the pre-heating .
If the starter is not operated, when the warning light goes out, the glow plugs remain supplied for a maximum of 10 seconds .
During the starting phase, the glow plugs are supplied under the following conditions :
* the coolant temperature is below 20 degrees C
* the engine runs at more than 70 rpm for 0.2 second(s)
Andy.
