Xantia HDi 110 Exhaust Diameter
XantiaMan
x 18
Unread post by XantiaMan »
Anyone able to tell me the pipe diameter?
2020 Peugeot Partner
2017 Fiesta ST
2001 Ford Puma 1.7 VCT
2006 Ford Fiesta Zetec
http://www.facebook.com/kidmans" onclick="window.open(this.href);return false;
electronmirror
x 30
Unread post by electronmirror »
Hi there,
According to Bosal catalogue the 110 is 60 mm diameter The 90 is 54 mm diameter. Those dimensions apply to the hatchback as well as the estate exhaust pipes.
Regards,
Ted
Ted
2010 C5 2.0 diesel(163) Exclusive Tourer (135,980miles)
1999 Xantia Exclusive Estate 110 Hdi Mauritius Blue with self peeling lacquer finish (276,174miles)
1991 XM Prestige 2.0 Auto(157,000 miles) gone but not forgotten
XantiaMan
x 18
Thanks for that. Must be 2.25in internal diameter..
2017 Fiesta ST
x 1488
But the rear box is the same dia as the lesser models, so the pipe swages down at the inlet to the box. On most cars the exhaust is one piece from engine to back box, including a CAT, and is fearsomely expensive. There is a repair pipe aft the cat available at a much more reasonable price!
XantiaMan
x 18
Its the repair section i am after. As per my progress thread, the Activa pipe diameter is an abysmal 54mm, and people wonder why they run out of puff??
Plan is, to obtain the 110 HDi repair section. This removes one of the boxes from the system. The extra diameter will make all the difference. The repair section will be mated up to my decat pipe, which fingers crossed, will be the bigger diameter pipe to match. Then, i only have to fit a compact silencer at the rear, weld on the tailpipe of my choice and we should have a good performing system for less than £100, the gains should be impressive actually as removing just the baffled silencer on my old Activa for a straight through helped the top end. Cant wait!
2017 Fiesta ST
HDI
x 7
Unread post by HDI »
HDI 110 rear boxes do have the larger diameter inlet and a larger diameter tail pipe.
Now using '00 Xantia LX HDI, pov spec :(
My past Citroens :-
'00 Xantia SX HDI, now dead due to accident :(
'99 Xantia HDI 110 Exclusive, RIP :(
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
'79 CX2400 Pallas (scrapped :( )
& a couple of Peugeots !
x 1488
We're both party right, HDI.... :lol:
None of the rear boxes are larger (well except maybe for the V6!*) - and in fact looking at it, the larger pipe only appears to apply to cars post Nov 99 when the EEC 2000 engine came in, and the exhaust went one piece from engine to rear box.
* there is also a 2.0T specific rear box, but not sure why!
XantiaMan
x 18
I'm not interested in the back box, only the pipe from cat to back box.
My calculations are not exactly correct though. The OD of 55mm could easily reduce to 51mm Id once the wall thickness of the pipe is taken into account. 60mm is closer to 2.5 inch, which is exactly what i want.
Anyway here is the pipe in question -
http://seekpart24.com/bosal/repair-pipe ... 7?c=100047
Designed to slip over the cut off section of pipe from the CAT if the centre part is rotten but that CAT is fine, it then has the standard flare at the rear, which i will fit an aftermarket backbox onto. The front part will fit onto my home made down pipe.
2017 Fiesta ST
HDI
x 7
All I can say from my own experience is that the box on my '99 HDI 110 has a larger in and out pipe than the 90 version. This is a 3 piece system.
I used a repair centre section to rebuild the system recently.
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
