1998 Xantia Mk2
Recentley the remote fob decided not to lock/unlock doors, as i have found out that you cant re-program used ones i want to check the problem.
Should the Alarm(hazard lights flash) turn on using just the key?
Is there anything else worth trying before i get new fob, key reprogrammed?
Where is the reciever for the RF fob?
Any help on this appreciated.
Can any auto-electricianreprogram a fob?
Thanks, Will
Xantia fob remote locking/alarm not working
admiral51
- (Donor 2026)
- x 391
Hi Will
Simple question first have you checked/changed the batteries in the fob
No the indicators will not flash when using just the key to lock the lock the car as you are not setting the alarm.
The reciever is on the drivers door by the movement sensor in the plastic cover by the door mirror.
I doubt very much if an auto electrician could reprogram the fob unless it is a new un programmed one reckon its a Lexia or dealer job
Colin
Colin
Toby_HDi
- x 3
Maybe it just needs re-synchronising. I believe the procedure is to pop the key in the ignition, turn on the ignition and press the button.
Toby
Previous:
2004 Peugeot 407 HDi 138 SE Luxury Pack
2001 S2 Xantia HDi 110 SX
2001 Peugeot 406 V6 Coupé
1998 S2 Xantia Activa
2000 S2 Xantia HDi 110 SX
1999 Peugeot 406 2.0 16v Estate
Previous:
willhay33
