egr blanking berlingo 2004 dw8 b/l4??
jezmondo
Hi guys,if i remove pipes from egr is that enough to disable egr??i did this last night and did seem to have a little more pull..
- x 1056
jezmondo
- x 1056
jezmondo
- x 1056
jezmondo
dont spose you have got a pic? mine does seem to have two.well on the senser that controls it anyway,its near the battery tray
i looked up the part called egr and it looks like this
http://www.google.co.uk/imgres?imgurl=h ... 20&bih=567
jezmondo
- x 1056
Thats the not the EGR valve, Thats the electrovalve that controls the amount of vaccum. The EGR vale is attatched to the inlet manifold.
You could also disable it from here also though by blocking the rubber pipes at the electrovalve. I hope you marked which pipe goes where incase you need to re instate the EGR.
- x 1056
http://service.citroen.com/docapvdp/AC/ ... 56g75a.jpg
Actually thinking about it that electrovalve is for the EGR throttle butterfly not the EGR valve itself so doing what i said above will blank this (which is a good thing also)
The EGR valve is the smaller part of number 14 in the pic & its electrovalve is built into it so you need to pull of the longest number 2 pipe at the end of number 14 & blank this pipe.
Clogzz
- x 40
jezmondo
citroenxm
- Fallen Hero
- x 70
