Xantia Front Wheel Bearing R&R
Post Reply
addo
Sara Watson's Stalker
Location: NEW South Wales, Australia. I'll show you "Far, far away" ;-)
My Cars: Peugeot 605
Citroën Berlingo
Alfa 147
x 93
Post by addo »
Just want to check, as BOL is no use whatsoever!
From a stripped/dismantled state:
  • Extract dust seal if fitted, then outer races by "bead of weld" method.
  • Strip inner races with puller or cutoff wheel.
  • Deburr/prep with lube of choice, and press bearing into hub carrier.
  • Support hub carrier from rear with press block (tube) bearing upon inner race and press in hub.
  • Fit snap ring/dust seal if applicable.
Thanks, Adam.
Post Reply
