Hi guys iam a total newbie on here, hi there!!
Just wonder if its possoble to swap my lucas fuel pump for a bosh on my 04plate berling??
what bits will be needed?
and does anyone know of anyone that has done this ok??
Thanks guys jez
dw8b/14 2004 berlingo poss to swap lucas ip to bosh??
jezmondo
citroenxm
- Fallen Hero
- x 70
This has been VERY sucessfully done on older XM's with Lucas mechical pumps and later XMs with Lucas EPIC semi electronic..
IF you fit a 100% Mechanical Bosch Pump, you WILL also need the Pipes and Injectors as the pop pressures are different, and the Timing OUTLETS are in a different position - they still fire 1,3,4 and 2, with No.1 at the gearbox end...
XM's have succesfully run on Mechinical Bosh when they were Lucas EPIC, with little wiring mods etc etc..
You WILL also need to move the mounting studs on the Pump Back plate - once you remove the old pump you will see the studs and TWO other stud positions next to each stud, the studs - 3 of, need moving to the next ADVANCED position on the back plate - if you dont, you'll never get the thing running... Timing must be completely different internally on each pump.
Paul
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
jezmondo
citroenxm
- Fallen Hero
- x 70
If your fitting a mechnical system, then yes I think you could get away with that, but useually the EGR is connected to the inlet manifold, not to the pump.. so shouldn't be affected...
Paul
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
jezmondo
jezmondo
citroenxm
- Fallen Hero
- x 70
jezmondo
thanks for all your help!
my mates a mechanic and he has looked it it,he will be getting me the bits needed and fitting it .
Iam into running cars on vegi oil so going to twin tank it ,cant wair..free fuel!!
The vans quite tidy soshould be good for a few years yet!.
berlingo 2004 1.9 diesel lucas pump
