Hi All.
I been trying to find the link to a topic about getting to the rear
spark plugs on a Xantia V6.
Could someone please help me find it.
Thanks H.
V6 SPARK PLUG
Toby_HDi
- x 3
Hopefully I don't get shot down for linking to another forum but they share the same engine so this should help.
V6 Spark Plug How To
Toby
Previous:
2004 Peugeot 407 HDi 138 SE Luxury Pack
2001 S2 Xantia HDi 110 SX
2001 Peugeot 406 V6 Coupé
1998 S2 Xantia Activa
2000 S2 Xantia HDi 110 SX
1999 Peugeot 406 2.0 16v Estate
Previous:
DickieG
- Monaco's youngest playboy
- x 38
Don't know what link you're referring to but in a nutshell you need to remove the inlet manifold (new gasket required just a few £ from a dealer) to gain access, here's a photo of what you'll see when the manifold is removed.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
DickieG
- x 38
That link doesn't work for me Toby, it states I need to be a member to view it.Toby_HDi wrote:Hopefully I don't get shot down for linking to another forum but they share the same engine so this should help.
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
Toby_HDi
- x 3
Ah bugger, forgot about that. Was a step by step guide showing spark plug renewal on the ES9J4.DickieG wrote:That link doesn't work for me Toby, it states I need to be a member to view it.Toby_HDi wrote:Hopefully I don't get shot down for linking to another forum but they share the same engine so this should help.
Oh well, as you said Richard, inlet manifold off to get to them.
Toby
Previous:
Previous:
- x 8320
Just being pedantic here but there is no need to remove the throttle body itself from the inlet manifold when listing it. Provided you disconnect the wiring, the throttle cable and the breather pipe that goes into the concertina, it will lift off fine.
Be aware that there are two more bolts at the rear of the manifold that attach the lifting eyes to the manifold.
You need a long socket or box spanner to remove the plugs and if they have not been out in a while, they can be tight so go gently. It helps if the engine is warm and a tad of Plus Gas is sprayed down the wells. Use an air line to blow any debris out of the bottoms of the plug wells before you start.
The front plug wells may have a smidge of oil in them. The worst is always the one nearest the oil filler due to spills when topping up and so on.
A new gasket is essential. Part No. 0348 K7
Take care not to damage the cruise control bellows and ensure the wiring loom behind it is completely clear of the bellows on reassembly.
